1 - 12 of 12 Posts
what is the standard thread size on a holly main body for the bowl bolts? i have two stripped and need to get a couple heli coils for it. thanks guys
Its 7/8 x 20. I dont believe a helicoil exists for that. You probably have to get new bowls.
the bolts thread into the main body.. thats where its stripped..
Not sure what BLP has but Roush Yates sells a neat kit that has drill,tap,inserts ,installation tool and a locating block so you can drill the hole correctly.
Discussion Starter #8
Thanks for the help guys!
The heli-coil kit should've been standard with any BG carb shipped out, lol.
X2 !! Gold claw bolts barely reached the main body....Had to do all 8 !!
1 - 12 of 12 Posts
