I keep having the same dream ,it started in the early 80's
I am building a head ,my own design, for a one cylinder motorcycle it is a four stroke but it has no valves. It has 2 tubes that run by a chain from the crank. One tube is the intake the other tube is the ext . AS the tube turns a hole in the side lines up with chamber to allow the intake charge to enter the cylinder as the tube turns the hole is closed ,the engine fires as it turns more the other tube witch also has a hole in the side lets the ext exit the engine .
no valves to fail
much more rpm
no loss of hp due to friction
no loss of HP due to high spring load
no cam
no valves to fail
much more rpm
no cam
