No guts, no glory or just maybe guts and a fail? We will see how it actually comes out. Might be good, might not be good but think I may just get lucky.
Picked up a prime tenderloin and rack of lamb at Costco for the holidays and happened to stop by good ol Kroger checking out deals and ran into one and bit on it. Personally not a huge fan of the regular beef at Kroger but this was just too cheap to pass up. I prefer prime for the holidays, but some things are hard to walk away from.
Doesn't have the marbling I like but it is from the ribs that I like and doesn't have any gristle so I think I can make it work. Honestly was just going to age it and have it ready in case anyone wanted some but my son bought movie tickets X-mas day for the new Star Wars movie in the afternoon so the timing to make it works out well. While we are watching the movie it can be holding in the oven. It will cook for a full 12 hours except for initial browning and additional browning in the broiler at then end. The temp of the oven will never go over 200 degrees and most of the time around 120.
The first thing I did was take it out of the Kroger plastic and rewrap it in cooking plastic and then into a plastic bag that has the air removed. Important when wet ageing that you remove all the air and the meat not exposed to oxygen.
That was 9-10 days ago. It won't age as long as I would like to be eaten for X-Mas but I think it will be OK. Thursday I will remove it from the plastic, cut the ribs away from the main section and do a heavy Kosher salt rub. I will reattach the ribs to the main section using string and dry age for 3 days more days. For the initial browning I will remove the ribs again, and brown both sections except for where they meet. I will again reattach the ribs, tie everything together with string and throw it into a 200 degree oven which I will turn off when the internal temp hits 100. If it rises too much I will completely remove it from the oven to prevent over cooking. Will then hold the internal temp between 110 and 120 for the rest of the day. The only seasoning will be salt and pepper. Nothing else is needed for good beef.
To be continued. Real time, is real time. It will take a while.
Like Anthony Bourdain said about Rachael Ray's 30 minutes meals............ "Nothing good happens in 30 minutes."
Denny
Denny
