Got ya.. Brodix would get my pick.. Rodeck only makes a 9.025 deck, Donovan uses the same material type as Dart does.. Brodix uses a good grade aluminum, uses reinforcements in the valley area and you can order it full water jacket, 1/4, 1/2, 3/4 or totally filled.. Rodney Lambert uses this block and they say they like it alot. Huber used the Dart junk like I did, then went to a Brodix then moved to a iron block.. The problems he was having is the same I was.. Main caps moving and blowing out main bearings.. The epoxy help this problem a lot for me and I was on the same mains all last year.. Just went thru a lot of pistons.. <<not nitrous related at all..
