1 - 6 of 6 Posts
Hi what material band should be used with a aluminum reaction carrier in a TH400? I assume not the stock metalic. Is a kevlar band correct or is there another material out there? if so part number /brand and where can i get one asap?
Ryan
I don't use them as they all seem to fall apart or break. Why do you want this part? Its worth nothing in the way of ET and its not a very active part. In low its just hanging out , in 2nd its running at half speed and of course it eventually gets to the driveshaft in high gear. It has a lot of time to get there so its basically just worth static weight and I have yet so see one survive.
Hutch
thanks maybe i will see if i can get a stock carrier machined to same dimesnions and accept the pinions form the aluminum carrier.
Ryan
1 - 6 of 6 Posts
