Im trying to figure out if i have my transbreak wired wrong or what. I just changed from c4 to th400 and when i put it in reverse it starts to move without pushing the transbreak button, is this how the th400's are or do i have this wired wrong?
Unless it was suggested to put the trans in reverse THEN press the TB button to go backwards should you do that. If you are not sure I would suggest putting the car in neutral then pressing the TB button for reverse until you know what brand of brake you have.
