I am building my 400 and installed my intermed and found my clearence with a flat steel (no wave) to be .040 then I relized I had a steel piston so I bought an aluminum piston installed it and reassembled it. now with no wave I have .008 both of these measurements are with a 106 upper flat snap ring .
Now I installed the 400 wave and removed a clutch to 3 total clutches but i have .050 with wave and having my stack consist of wave/clutch/steel/clutch/steel/clutch/steel/pressure plate.
Now should I run the wave with a steel to the pressure plate and leave .050 or
should I pick up a thinner .077 flat final snap ring and run 4 clutches with proper steel to clutch with no wave ring?
This trans is behind a 496 bbc in a 69 skylark and has a tci transbrake with 34 element sprag and drum set and I rollerized the output shaft pressure area at back of trans. I followed all other factory specs other than what my transbrake told me to do. I ran my direct clearence at .070 because instruction told me to run that with no wave in direct
One last question
when I install my reverse band piston it applys the reverse band just by installing it. Is it suppose to do this then pressure releases it when needed?
thanks for any and all help guys
One last question
