Would you rather use a 3 clutch stack with the thick .092 frictions and the .100 steels or a 4 clutch stack with the thin .062 frictions and .065 steels. Either way I go these will be on top of a wavy steel and I am using the stock 400 pressure plate. Any suggestions?
I have always preferred the thick clutches. Its a 34 element sprag on an aluminum drum if that makes a difference. Im just trying to get away from this sprag rolling crap.
