Once I hit the button it doesn't release. Both for reverse and for 1st gear. It also doesn't move in 1st unless I shift
According to this statement it is locked in first gear without or before pushing the button.Is this correct?Internal or external solenoid brake and brand?Once I hit the button it doesn't release. Both for reverse and for 1st gear. It also doesn't move in 1st unless I shift
Spin the tires by hand? Same or opposite directions?Update
Pulls noid. It seems to pull back. I can push my finger on the inside of the trans case and push the valve and it returns closed
I also noticed on the jacks I can spin the rear tires in park.
Thoughts
