1 - 3 of 3 Posts
I have a TH350 with TCI reverse pattern valve body. When I shift from 1-2 it does not shift right away it goes up 200 to 300 rpms then shifts. When I shift from 2-3 it shifts immediately. Any suggestions on what to look at. Thanks.
If you are sure of oil level and shifter adjustment the only other cause would be system pressure (too low) , clutch clearance, clutch type or steel condition/finish.
Hutch
1 - 3 of 3 Posts
