1 - 7 of 7 Posts
I had a turbo 350 built for drag, with 3500 stall. The engine is about 525hp and gears are 308 ratio. It pulls hard later on but will not spin tires on take off. No torque. It is shifting fine. Any ideas guys. Thank you
Sent from my SM-G920V using Tapatalk
IMHO 3500 stall 3.08 gear wont be happy.My mild sbc pump gas small xe274h cam th350 has a 3600 stall 3.73 gear.1.68 short times will blow the tires off if the track prep isnt there.Tuna boat at 3600 lbs curb weight.My trans is bone stock other than a shift kit and 3600 stall verter.
Mine wont even power brake...
King Ding-A-Ling
You may get more help if you posted this in the correct section........ Like the transmission section not the YellowBullet Nationals section
1 - 7 of 7 Posts
