I need the rear planetary and the rear/low sprag with center support .There is a front and a rear planetary. As there is a front/intermediate and rear/ low sprag. Which are you referring to?
The point Hipster was trying to make is that a Glide is the upgrade...Glide?
I understand that a glide would be much better. But this is a 4wheel drive mud drag. All I do is trans brake and run 1st and second gear. my final gear ratio in second gear is 6.90.The point Hipster was trying to make is that a Glide is the upgrade...
Depending on how many passes your making per year sounds likethis tranny has held up very well for 3 years at the track.
Plastic bushing is better IMO. Nothing will live without lube.I have a 700R4 center support its galled up the wide roller clutch is burnt and the rollers are 1/2 missing. The rear sprag is junk the snap rings on the sun shell are popped off one is missing and the small bushing is melted Right out of the output shaft. I am thinking the cheep plastic bushing might be the cause of all this. don't know why someone would use a plastic bushing with a full race trans brake tranny. Not saying the HP had any help but with the bushing completely melted it was very sloppy in there. A bronze bushing will go back in. anyone see this before?
