Are you sure your checking it correctly ? You don't have enough of water or E85 . It is not filled to the line.
Ethanol will hold a certain amount of water,
If you take 50% water and add 50% E85 it will not read 100%.
as phase separation happens, some of the water bonds between the alcohol molecules and you will get a strange reading.
what we have found is the more the over all line drops the dryer the alcohol, this didn't move much so the Ethanol must have been holding some water in it.
when he filled the shaker tube im sure he filled it to the line, the new level shows how hydroscopic (wet) the fuel was.
the fuel in the tube is E70, the gas is in the middle and some type of additive is on the top.
Mark Sullens
