1 - 20 of 45 Posts
Post all of your values for the required parameters displayed on the software screen shot below. They have the white background boxes. With this software in AutoCalc mode, it will calculate your ports allowable mean and max velocity capability, then make all design decisions and give you instructions to follow if your assistance is needed.
We will model your engines in AutoCalc, and display a screen shot of the results. VE%, Max Design FPS and Curtain Adjust values are not required.
I think i have all the numbers
number of cylinders 8
bore 4.185
stroke 4
rod center 6
piston pin height 1
flat top
neg 9.3cc
MCR 13.21
head gasket thickness 0.1
h-gasket bore 4.2
block to piston deck 0
intake--------------------- exhaust
1 number of valves 1
2.185 valve diameter 1.625
0.343 v stem diam 0.343
? td/vd% ?
0 throat boundary layer
bench test
28
@500 lift in-330.2 ex-241
@600 lift in-353.37 ex-251.76
@700 lift in-366.5 ex-262.5
max hp rpm 8000
intake 1.6 rocker
exhaust 1.6 rocker
n/a
e-85
solid roller.
These are the results made in autocalc. I would have a couple of questions. The first being, does your ports continue to hold their flow to .850" lift and how much valvetrain deflection does your valve train have?
I have a 572 ci Ford. Here are the specs I know
Cylinder: 8
Bore: 4.500"
Stroke: 4.500"
Rod: 6.700"
Compression: 14.3
Valves: 1 intake 1 exhaust
Intake Valve: 2.250"
Exhaust Valve: 1.76"
Stem Diameter: .341"
Throat Diameter Intake: 91.1%
Throat Diameter Exhaust: 90%
Flow @ .500- 355 intake/191 exhaust
Flow @ .600- 379 intake/215 exhaust
Flow @ .700- 397 intake/231 exhaust
Flow @ .800- 401 intake/238 exhaust (max flow lifts)
Max HP RPM- around 6500
Rocker Ratio Intake & Exhaust- 1.8
Valvetrain Deflection- .030"
Thanks!
The engine model shows that your intake port flow and velocity capability is excellent for the valve diameter size. But, is not proportional to the needs of the cylinder at 6500 RPM.
To raise the mean velocity to the ports capability we have put the throat velocity well into choke for many degrees of the intake cycle.
A 2.300 valve with 93% throat diameter percentage would better suit this combination.
Discussion Starter #7
RWMOTORSPORTS
For your information, this is the autocalced results. You can see the maximum throat velocity is much lower than the 800+ on the other model. But the mean port velocity is very slow when compared to your ports capability of approximately 350 fps. And mean port velocity is directly related to the VE%.
put down what I knew
bore 4.030
stroke 3.622
rod center 6.125
dome 4cc
MCR 12.5/1
head gasket thickness 0.40
h-gasket bore 4.035
block to piston deck .01
2.100 valve diameter 1.600
bench t
@500 lift in-325 ex-2227
@600 lift in-335 ex-234
@650 lift in-339 ex-241
max hp rpm 7500
intake 1.7 rocker
exhaust 1.7 rocker
nitrous
e-85
Discussion Starter #9
This was straight forward in design and is using most of the ports velocity capabilities, but not all. I didn't add the Nitrous, but will send you another screen shot with a 100hp shot.
Lets give this basic SBC a go...
8 cyl
4.030 bore
3.48 stroke
5.7 rod center dist
1.548 piston pin height
6.90cc valve reliefs flat top
10.2 mcr
.280 head gasket thickness
4.100 head gasket bore
.015 piston to deck
2.05" intake valve 8mm
1.60" exhaust valve 8mm
275cfm intake @ .500
280cfm intake @ .550 (max)
217cfm exhaust @ .500
218cfm exhaust @ .550
6,000 rpm max hp rpm
Normaly Aspirated
Gasoline
1.6 rocker arms
Thanks-Jim
Busy being a cunt
8
B 4.400
S 3.500
Rod 6.585
PH 1.505
Dome 50.6
CR 13.5:1
HG .040/ 4.600
ZERO DECK
IV 2.280/ .343
EV 1.880/ .343
.200....167....157
.300....245....201
.400....313....256
.500....365....293
.600....400....318
.650....408…..324
.700....417....329
MAX RPM 8500/ PEAK 8000
VE/ ?
NA
E85
ROCKER 1.7/1.7
Discussion Starter #14
thanks a bunch. it's built for a 300 shot sorry forgot to add that.
do you sell cams?
Not anymore, I've spent the past 5 years working on this software that designs the cams, generates the profiles and saves them to a file that can be read by a CNC grinder. So, you or anyone else can have your specific cams ground. Howards Cams is one company that will grind them.
cyl -8
bore 4.185
stroke 3.875
rod 6"
dome
1.062 pin ht
041" gasket
4.200" gasket bore
deck .004 in hole, block to piston
42.2 cc head
valve relief 6.5cc
1.7 intake rocker
1.6 exhaust rocker
5/16 int stem 2.18" dia. 1 valve
11/32 exh stem 1.625" dia 1 valve
int. throat 1.994"
exh. throat 1.4625
flow my bench
int. exh.
.2- 147 104
.3--228 156
.4--296 204
.5--346 233
.6--372 251
.7--389 258
.8--395 266
.9--399
max hp rpm 7600
8100 shift
methanol
N/A
mfi tunnel ram 1800 cfm bodies
Dwight
Discussion Starter #16
8 cyl
4.030 bore
3.48 stroke
5.7 rod center dist
10.2 mcr
.015 piston to deck
Normaly Aspirated
Gasoline
1.6 rocker arms
Thanks-Jim
Discussion Starter #17
8
B 4.400
S 3.500
Rod 6.585
PH 1.505
Dome 50.6
CR 13.5:1
HG .040/ 4.600
ZERO DECK
IV 2.280/ .343
EV 1.880/ .343
.200....167....157
.300....245....201
.400....313....256
.500....365....293
.600....400....318
.650....408…..324
.700....417....329
VE/ ?
NA
E85
ROCKER 1.7/1.7
Discussion Starter #18
cyl -8
bore 4.185
stroke 3.875
rod 6"
dome
1.062 pin ht
041" gasket
4.200" gasket bore
42.2 cc head
valve relief 6.5cc
1.7 intake rocker
1.6 exhaust rocker
int. throat 1.994"
exh. throat 1.4625
flow my bench
int. exh.
.2- 147 104
.3--228 156
.4--296 204
.5--346 233
.6--372 251
.7--389 258
.8--395 266
.9--399
max hp rpm 7600
8100 shift
methanol
N/A
Dwight
This is a good one. The ports are capable of creating the Potential VE% (circled ), so we designed for the Potential VE% by selecting the Potential button (circled).
SBC
8 cyl
4.155 b
3.8 s
6" rod
1" pin ht
dome vol 2.5cc positive
.041 gasket thick
4.166" gasket od
head cc 53
2.16" int .312" stem 1.9656 throat x1
1.625" exh .342" stem 1.4625 throat x1
heads flow
int exh
.2=160---111
.3=236---162
.4=299---208
.5=337---241
.6=364---261
.7=374---272
.7=378---276
T-ram
two toilets 1500cfm
injected methanol
7700 rpm hp
1.7 int rocker
1.6 exh rocker
Discussion Starter #20
SBC
8 cyl
4.155 b
3.8 s
6" rod
1" pin ht
.041 gasket thick
4.166" gasket od
head cc 53
heads flow
int exh
.2=160---111
.3=236---162
.4=299---208
.5=337---241
.6=364---261
.7=374---272
.7=378---276
T-ram
two toilets 1500cfm
injected methanol
7700 rpm hp
1.7 int rocker
1.6 exh rocker
1 - 20 of 45 Posts
