1 - 5 of 5 Posts
I just have a couple questions about one. Is it an on off valve or is it a check valve?? Like if I energize the solenoid, then apply the brakes will it still work??
After installing it and bleeding the brakes push the pedal and set it. After you have it set try to push the pedal again and see if it is rock hard. Then let go of the button and set it without pumping the pedal to see if it will allow you to put pressure in the system after its set. This has been talked about before on here and got a lot of mixed answers. Mine won't let me put pressure in the system if I set the LL and then try to put pressure in the system. I have to set the brake first and then set the LL for it to work.
Okay I was hoping it wouldn't take any extra pressure after the button is pressed. Which make is yours??
yes my old tci would only block flow and would'nt flow after being applied,i dont know that newer ones are any diff.
1 - 5 of 5 Posts
