1 - 2 of 2 Posts
If u took a 2000 hp blow thru 540 bbc on steves dyno and replaced the trash can full of ice water with lake water for use in a boat, how much power would be lost????????????
Shouldnt be much if any. You would have an endless supply of stable lake water temperature where as in a car you have a limited amount of say 5-12 gallons your continuosly circulating till your ice runs out. Not sure how much lake water can vary in temperature but if it ranged from 60-90 degrees you'd probably just wanna tune it up for the "worst case" temp.
1 - 2 of 2 Posts
