1 - 6 of 6 Posts
Im almost in the final stages of completing my 800 hp lsa swap in my chevelle. I want to go with a t56, I know their rated at 700hp. Do you guys think it will hold with a good clutch?
Sent from my SM-G955U using Tapatalk
Don't think any stock T56 will reliably hold that kind of power so no not advisable.
Now if you're talking about purchasing a new Tremec Magnum trans different story not a problem.
What torque is your motor putting out and what are you going to do with the car?
You should probably repost in the stick shift section of this forum and you'd get more replies. https://www.yellowbullet.com/forum/forumdisplay.php?f=119
I had a Jerico in my truck. 700+hp. Single disc clutch. 5800rpm and drop the clutch. Pull second gear at 7 grand going past the tree. Yee FUCKIN' Haw!!!!!!!
1 - 6 of 6 Posts
