Yes, thanks very much for taking the time to explain in detail how it’s done. Very grateful for that.
I think your diagram confirms the Manton instructions as well, which dictate that roller tip starts on the “inboard side” (closer to rocker fulcrum) of the valve stem and as the valve opens, it moves outwards away from the fulcrum so that by mid-lift, it’s an equal distance across the center on the “outboard side” of the stem, then rolls back to where it started.
It’s very useful to know what the width of the sweep should be (0.050”) so many thanks for that.
The only reason I‘m considering lash caps on the exhaust valves is because I couldn’t get the exhaust stand low enough to meet the T&D instructions, which call for my exh rocker shaft to be .033” lower (.816“ lift) than the tip of the tool. So I added the lash caps to lengthen the valve and then shimmed the rocker stand to try to hit that number, and I can get real close to it (~0.035”) doing that.
But the strange thing is that I can’t see a better pattern doing that anyhow, although the lash cap is harder to read. But I’ve looked at this damn thing now until I’m cross-eyed, so I’m going to put it together with the recessed locks on the exhaust - so that I can use lash caps if I “need” to - but will use a test spring and roll the motor over until I can get a reading on the valve stem and see what that gives me.
Because at the end of the day, it’s where the roller meets the valve stem, and how much it moves across it that matters.
Thanks again for all the help.
Wait…”pushrod geometry“ you say??? JK, I’m confused enough as it is now, lol.
