I have 2 foggers on the motor and want to try and leave with the smaller one just to get it going. Then switch them and turn the larger one on.
The smaller is 22/26 's the larger is 28/32's.
I will try and run the small one for about 1 second then turn it off and turn the larger one on. Do I need to do anything special or just set the timers and the amount of retard to take for each as normal and let the ignition and delay box handle it all.
Figure set the first timer at .05 to 1.00 and the second 1.01 to 6.8 ??
Sounds like it should work?
