1 - 4 of 4 Posts
Need some input on whats best best intake for the money to use on 632ci 18* BBC headed motor? Switching from nitrous to turbo. Also any ideas on cam specs and compression ratio would be great.
Thanks,
Coop
Custom Engine Shop
Aaron,
What are you going to do with the motor?
Type of Fuel?
Which heads?
HP goal?
Class?
We are planning on running the limited street class. We're running the 427 Pontiac 18* casting head and are planning on running vp116 gas.
Aaron,
I have a 632 with a 14.5 degree head that i switched from nitrous to twins this past winter. What turbo(s) are you planning on going with? Alcohol or gas? Intercooled? What EFI system? What cylinder heads?
Later, JW
1 - 4 of 4 Posts
