1 - 6 of 6 Posts
We switched from a stock case to an ati supercase and changed nothing else now we have no reverse. It has a tci sportsman brake valve body. i verified the rear support is on correct and the 5/16 cup plug ati talks about in there instructions was not needed. Any ideas?
I tryed it with the linkage unhooked and had low and high gear. In reverse the wheels crept forward just like they do in netural. The transbrake clicks but does nothing. Maybe this is an unrelated issue but the last time i tryed it, it devoloped a leak in the front pump/converter seal.
I normally use air to check the rear piston before I assemble the trans. with the reverse clutches in place I might add. :0)
1 - 6 of 6 Posts
