1 - 20 of 91 Posts
I went from a 84mm to 91mm S400 . Both turbos from Forced Induction .
Just put it on the brake for the first time with the track tune .
Only made 7psi @ 4200 rpm no matter what I put on the gate .
The 84 made 11psi very quickly , the 91 takes twice as long to make 7 psi .
So now I wonder how slow it will be through the eighth mile .
The old turbo made 30psi before the 1 2 shift .
Ive always said street is more important , and its OK on the street but the 84 really spooled much quicker .
I always kept the timing in it and lean on the brake ....... really didnt want to mess with pulling timing adding fuel boost builder crap .
I might have a 91 for sale soon . :unsure:
Boost builder should help. It kinda did for me on my bbc car but i havent finished playing with it.
But on street it may be alot slower to spool. Not much you can do there. Wrap the exhaust to keep heat in maybe
Im going to mess with the boost builder , but if it isnt much better , this turbo is coming off .
I was very happy with the way it ran before , but was looking for a little more .
I wasnt looking to spend a bunch of time on this though .
Hell , I had this thing down to 1.24 to the sixty and 5.60 to the eighth . Been 8.78 @ 156 ......... Went 8.80 on its last outing .
But I just had to fuck with it !
Is there any other housing options for that turbine?
I think Ill put the old turbo back on and see how it acts with the new cam .
Just to make sure its not something else .
Because it also seems to struggle more to get up on the converter
I went from an 80/96 to a 91/102 and it’s not anywhere near as bad as what your describing on the street it’s around 500rpms slower to spool then the 80 but at the track on the 2 step it’s within 1 second of the 80 to 11psi it did take more dome psi after the t-brake release to get it to come on quicker but I have it making 25psi in .48 seconds
Give the old turbo a try maybe the new cam is that much different??
If I remember right you have a 12 stator. I wonder if that combo is gonna want a looser converter. I know you pull your boat with it though. I run a 15 and my car is 4200+. I thought mine was tight. I cant imagine a 12.
OG Member since 9/7/06
Spray that bitch
Discussion Starter #13
Im told the new cam is very similar , just a little more on the exhaust side for the bigger turbine .
Discussion Starter #15
I really didnt want to have to spend a lot of time making it work . I was ok with the slower spool on the street , but Im not wanting to spend a lot of track time trying to run 2 tenths quicker .
Sure a 8.50 at 160 mph would be great , but Im OK with what it runs with the 84 .
Plus I have a hunch that it will be slower to get to max boost during the pass also ????
Theres gonna be a difference in 96 turbine and a 104. Also the 91 comp vs an 84.
you will have to try it and find out. Theres more power potential now with the 91/104
Discussion Starter #18
I just didnt think it was going to be that big of difference .
Dont get me wrong , I had no problems with the other turbo . It was better on the street anyways .
Just always wanting to go faster I guess
I just wanted to do it with little or no effort .. LOL
I just went through this. switched from a 85/96 to a 91/102 on my 5.3 . the 85 would make boost at 4200 . I had to raise the 2 step rpm to 4600 with the 91. I did a test at 5000 rpm and the boost went to 22 lbs...lol
Discussion Starter #20
Well after pulling that big ass bitch off and I was putting the old one back on . After having everything hooked up and bolted down , I started looking for the oil line and grabbed the nearest -4an line I see .
It was the BOV reference line that wasnt hooked up when I installed the 91 in the first place . WTF
So after I calm down a little , Ill go back out and put the 91 back on and test it .
But not sure why it was still making boost when driving it .
It might be a beast now ......lol
1 - 20 of 91 Posts
