1 - 7 of 7 Posts
I have a 2011 Ram 2500 and a 32' enclosed trailer... Every time I would drive the thing with the trailer on, it would sway like nobodys business. You couldnt take a corner without it trying to pull you into the other lane.
I figured that air bags might solve the problem, so I put some on in the spring. I went to haul the trailer again the other day and you can hardly keep it in the road. I ended up borrowing my dad's 2006 F-350 and it hauls fine.
The trailer hauled great with his truck, as well as my old 2003 Dodge, but the 2011 is a pile of shit when it comes to hauling.
I was looking at Helwig for sway bars, but dont want to drop the money on them if it is gonna be a lost cause.
Is it worth buying them, or should I just trade the thing in?
what tires are on it... I ask because my stock tires had a load range like the should be on a fiat.. I bought some 8 or 6 plys (don't quote me which) but man did it make a difference towing.. I also have the airbags.
my buddy has a 2011, it stays loaded, none of the probs your are speaking of, you sure something isn't broken?
post pictures of your hitch setup
It does have stock tires... It has air bags...
The electric sway control was a 2012 option....
I will have to go take some pictures of the hitch setup... Needless to say, I am pretty dissapointed that I spent the money on a new truck and to have it haul like shit... lol.
Mine tows 20000 + lbs just fine! I'm assuming its a bumper pull trailer not a gooseneck?? Have you checked your tounge weight? Tire PSI? All of this is important. Are you using a weight dist. hitch?
Make sure you have 10 ply tires with 80 lbs in them. Your airbags need to have a seperate valvestem for each side. If they are tied together they will not give you any sway control.
1 - 7 of 7 Posts
