We just finished up our 5th gen Camaro set-up and we are trying to get the car dialed in. The set-up is as follows:
Moser solid axle conversion with torque arm
Afco Big Gun shocks in rear with 175lb 10" spring
Santuff front strut setup with 14" 175lb spring
Car weighs 3850lbs with driver
Turbo setup 1600ish hp
Car is 53.4% on front
A/S is roughly 98% I/C height is roughly 10.5"
We are spinning on the hit. I have the TA 2nd hole from bottom (out of 4). LCAs are 2 degree down to rearend. Tires are 28x10.5S with tubes and beadlocks At 17psi
Rear shock compression 12 (of 22) from full stiff
Rebound on 15 (of 40) from full stiff on AFCO big gun shocks with 175lb springs.
Track prep was poor to marginal
Leaving on 7-8 lbs of boost all in (18lbs) on controller by 1.5 sec
tightened up rebound 5 clicks
(sorry for the sideways video)
