That was my thought. I am curious about what others think.The parasitic loss imop should be slightly less the less boost the engine is making . From a blower standpoint it is taking and compressing the same amount of air on either engine but the backup of boost in the plumbing you would think that you would use a little more hp to turn the blower with more boost upstream . JMOP
With respect to a centrifugal blower, which uses more power?
Same blower turning same speed on a bigger motor making low boost vs. on a smaller motor making more boost?
Or are they the same?
I know for fact #4 is wrong. With zero flow the blower goes into stall(might not be the right term) and drive loss goes way down.In all examples impeller @ max RPM
Case 1: blower discharging to open air. Makes no boost, takes least power to drive.
Case 2: discharging into big deal motor. Makes low boost, takes a relatively little power to drive.
Case 3: small motor produces high boost and takes more power to drive.
Case 4: closed blower outlet. Max boost and max power to drive.
That's how I reason it. At any given RPM power to drive the blower is probably proportional to the boost.
I remember u telling me with the discharge of the blower open it took a bunch of power to turn in testing. So that would be make #1 incorrect alsoI know for fact #4 is wrong. With zero flow the blower goes into stall(might not be the right term) and drive loss goes way down.
Shoot, we could barely get an F2 open to atmosphere to rev up when we tried it. I can't even imagine an F3I know when I was back at Procharger that the BBC dyno motor wouldn't be able to spin an F3 to redline when blowing into atmosphere but as soon as you restricted the outlet of the blower it would spin right up to redline without a problem.
Refer to basic fan laws (probably several online calculators out there to plug numbers into and calculate different scenarios) to better understand the impact of pressure and volume on the flow of compressible gases.With respect to a centrifugal blower, which uses more power?
