Racing this weekend ran into some problems? Car first off was running slow...7 tenths off of the number and 10 mph off.
Second pass after turning onto the return road oil pressure goes down to about 20 psi and and bounces and then back to about 60 psi but is fluctuating???? the pickup is bolted on. It is feeling rougher then usual and is lacking in power. Something is not right, so I pop the oil filter off at the track and cut it open and find small amount of shavings in the filter here and there.
Motor has only 50 or so passes???? What could have happened? Any Ideas?
