1 - 9 of 9 Posts
I want to stretch the quarters on my 69 Camaro.
I plan to have two different tires that I want to run.
M/T 31"-18.5" and Goodyear 32"-14".
Would opening things up 4" be enough for clearance for the 32" and also look ok with the 31" tire?
I went 6" for my 14x32's, and had good room . Make sure you've got the wwheel opened up enough so it isnt a pain to change itres or tires hitting sheetmetal. I say 4-6" will do ..DR.
Let us know how much you do.
What do you do about rocker panel? Just cut it and cap off open end?
A Senior Member
M/T 31"-18.5" and Goodyear 32"-14".:-Daw
You board or have some extra energy?
I found out the tire size I posted was wrong.
The tires that I got are 33- 18.5.
I did some talking with a friend and he recommends 4".
A Senior Member
Oh, just tried something new, cryotherapy. It actually helped, froze my balls, but helped my knee....LOL
Make sure they set the timer!
Those quarters sound like a winter project.
Discussion Starter #9
Yes sir, 3 minutes is long enough!
Winter project, that's the plan.
Talked to YB member that runs 33's and he said 4" is not enough, need to open it up 6".
1 - 9 of 9 Posts
