1 - 15 of 15 Posts
540 BBC, B&M Megablower, 2 x 850 Mighty Demons, 900 - 1100.
I've had it as low as 600 but really, anything below 900 it wants to start with that "blower lope" or surging idle.
Lots of guys think that sounds cool but I find it a PITA to drive like that
800-1300 then 800-1300.......
461 BBC.246*/254*@.050"....13% OD 8-71....7"Hg at 900-1000 rpm in park,same in gear with a 3500 stall converter.
1000-1200 here
352CI Small chevy, 8-71 BDS Air-Loc, 1 to 1 ratio, 16% boost, 9 1/4 to 1 ,AFR 227, E-85 with (16) 160# injectors, Big Stuff 3, Enderle Big and Ugly 5" blades with progressive linkage idles at 1,150 to 1,250 on street, makes 830 to the rear wheels and 1,000hp at the flywheel.
1050 - 1200 - BBC 427 6-71 mooneyham 20% Under Driven 2 625 AFB's comp cam 314HR running solid lifters 110 LS / 314 Duration .612 Lift locked at 31 degrees on the timing.
No surge just changes some when it warms up.
Mine has 2 Quick Fuel dominators, 10% overdriven,14psi, 10-71 with Teflon on a 496 Hemi @ 31 degrees. 1200-1300...any less and it starts rolling.
I had 14 blown cars in 50 years,never had one idle higher then 800 in gear.Some idled at less then 600...Oldhead
1 - 15 of 15 Posts
