1 - 5 of 5 Posts
Hi,
Just wondering which drive speed sensor kit I should use as the 10 bolt pinion support covers most of, if not all of the yolk stem.
There should be 2 holes drilled and tapped in the support 90 deg apart. The holes cover most sensor thread sizes or you can re-tap to any size. Just remember to install the split ring during setup of pinion support, you can't fit it after.
I use an RPM speed sensor kit if that helps.
Corey
1 - 5 of 5 Posts
