1 - 3 of 3 Posts
'Looking to purchase a new center section , this way I'll have 2 gear ratios to play with at the track, currently have a strange ultra center section and strange 40 spline axles. I've been looking at the mw pro stock center section, looks like its 15 lighter than the strange , and if i add the options to the strange ultra case that i'd like to have, the cost is pretty much the same. the strange looks beefy ( and heavy ) compared to the mw. using for a 1650 top sportsman 69 camaro at 2400 lbs. which do you guy/gals prefer, I known probably both good units and can't go wrong with either.
Both are probably equally unbreakable in your car but the Strage Ultra is stronger. I'd probably go with the MW for the weight loss in your setup
Will the weight loss (if you ran two different gears) effect how the chassis is set up? In other words, would you have to make (or unmake depending on which way your going) chassis set up adjustments with the gear change?
1 - 3 of 3 Posts
