Has anyone had an issue with the rotor not sliding over the axle flange? The original plan was to run the stock brakes (Explorer 8.8 discs), but decided to go to the drag brakes instead. The axles were ordered before the brakes, and the only dimension that was needed for the brakes was the diameter of the stub on the end of the axle for the retainer plate. Right now, we're measuring the axle flange at 6-1/4" diameter and the innermost part of the rotor at 6-1/8". Would it be possible and/or safe to turn the axle flange down so the rotor fits or try and get another rotor? I plan on calling strange tomorrow, but just curious if anyone else has run into this problem?
