1 - 6 of 6 Posts
Is there any trick to reducing the drag on the Strange front discs.I installed them to reduce the 80 lbs. the original ones carried and don't want the tradeoff of the drag.On my originals I used an old Super Stock trick made by Bowling Green Customs called a friction reduction kit.It utilized springs and softer pads.The springs and shims kept the calipers from riding the pads on the rotor,you could literally spin the front wheels freely.Now with the Strange Brakes if I jack the front of the car and spin the wheel I get maybe 2-3 revolutions.
Administrator
It the master cylinder is above the calipers you will not need a residual valve. Mine is mounted low now and am using a 2-3 (which ever it is.. not the 10# for sure) on the car.. Seems to work fine..
1 - 6 of 6 Posts
