I have a 02 mustang with a Moser 9" rearend 35 spline axles. I'm guessing it is a direct bolt in rear. I ordered 8.8 Strange rear brakes and they wont work cause the way the bearing mounts. Were did I go wrong here or will Strange brakes not work on this. I was told by a friend that these used stock 8.8 brakes. Is this correct? If so I need to figure out were im going wrong here.
