1 - 3 of 3 Posts
Does anyone know if all 33 spline axles that Strange makes are the same diameter? For example, could you take a Strange 33 spline axle out of a 12 bolt and use it on a Ford 9” 33 spline center section? Said another way, if you took a Strange 33 spline axle out of a 12 bolt and a Strange 33 spline axle out of a 9” and butted the splined ends together, would they be the same?
1 - 3 of 3 Posts
