Ok I have a sheet metal Hogan intake that had something dropped on the corner of the lip/flange of the plenum . It is bent down/curled about 1/4" . Whats the best way to straighten this without breaking it ?? heat ? no heat ? etc ... also have an aluminum sheetmetal Moroso dry sump oil pan that is a little warped on the pan rail ... how would you straighten these applications also ....
