1 - 20 of 22 Posts
Its stock suspension on drag radials
J&E POWER!!
what,s the minimum weight Denny ? too bad also they only fit a 255 tire without relocating the rear suspension inward as well .
and ya a old prostock truck motor in a vega would be one very cool ride :party
Depending on where ya race at, it's either 26 or 2700lbs for a N/A small block.
As far as the suspension and the tire... PHUCK IT, JUST MOVE IT.. Everybody else does.. Put a 315 on it and let it eat..
a 315 would require strecthing the 1/4,s as well , a 325 would fit with a minitub and relocating the suspension mounts i have a 76 hatchback that i,m gonna inboard the suspension and such .
as for weights of the cars there seems to be no standard some guys i,ve chatted with claim they weigh 3000lbs others claim 2600lbs i guess i,ll know for sure when i get one of mine scaled .
Why would someone want to put a torque arm on a mustang? A mustang suspension works if you know what you are doing with it. "Stock" suspension mustangs are in the 7s now, so unless you are planning on going faster? what would you need a torque arm for?
1 - 20 of 22 Posts
