1 - 20 of 339 Posts
I'm pretty pumped so I had to share with you guys...
Got the stock shortblock Ford into the 8's this weekend! New best is [email protected] [email protected] to the 1/8th
Boost is 24psi, 11deg timing at peak torque, 10.70 AFR (gas scale)
No video unfortunately but I did get a few pictures.
-Tony
Still can't believe thats a stock shortblock. Crazy......congrats man.
Discussion Starter · #5 · (Edited)
Thanks! Turbo is BW S480 from Jose at ForcedInductions.com T6 96mm 1.32 hotside
I forgot to mention my first 3 passes I let off at the 1/8th for IHRA licensing.
Here is a run down on the whole combo
1992 flat tappet 5.8 block std bore (rust pitted)
stock crank
stock rods and rod bolts
stock cast pistons
mahle replacement rings
king replacement bearings
melling select oil pump
china main studs
reiners 9 qt oil pan
tfs stage 2 cam
howards link bar hydro roller lifters
tfs push rods
crane roller rockers
tfs 170cc twisted wedge heads (out of the box w/61cc chambers)
tfs r lower intake
tfs r box upper intake
china 75mm throttle body
twin aeromotive stealth fuel pumps
aeromotive fpr
accel 160lb/hr injectors
megasquirt 1 2.2pcb running MSNS-E firmware (4 bar mapdaddy)
msd 6al
stock tfi distributor
borgwarner s480 w/race cover 96mm 1.32 a/r T6
china 60mm wastegate
reiners 1.625” headers and 2.25” fully divided hotside
5” downpipe
china 4” air to air intercooler
3” charge piping
china 50mm bov
reiners roller thrust C4 trans w/brake and other goodies
reiners 245mm spragless torque converter
8.8 with full spool, 31 spline axles, and c-clip elim stock drum brakes
reiners double adj upper control arms
reiners single adj lower control arms
reiners lower instant center brackets
reiners double ARB
reiners 10 pt 4130 cage
full interior
3200 lbs w/driver
-Tony
stock crank
stock cast pistons
china main studs
tfs stage 2 cam
tfs push rods
tfs r lower intake
aeromotive fpr
msd 6al
5” downpipe
3” charge piping
china 50mm bov
reiners double ARB
full interior
3200 lbs w/driver
-Tony
congrats that is really moving, waiting on the normal ford crowd to make sure you know that isn't a stock bottom end ;)
What vehicle did that originally come out of?
Platinum Member
Got tired of looking at that red vinyl top huh??? LOL
Congrats on the 8.80 timeslip, Ford Powa ftw!!
Discussion Starter · #10 ·
Early 90's Econoline van
HELL yeah! Nice work!
Edit: who is Reieners? Is that the "R" in TonyR85?
Yes.
Here is the bottom end
A buddy and I goofing off while checking PTV clearance...ohh yeah procomp head studs and composite head gaskets too!
Wayyyyy more left in it!
reiners double ARB
1 - 20 of 339 Posts
