1 - 20 of 62 Posts
Depends what year and what model. 5.3 =290-355hp. 6.0=325-400hp. Those numbers could be off slightly.
Elite Member
If you plan to stay N/A, the mud covered poor boy HP starts with the 6.0 LQ4. The 5.3 is a fuckin slug on nuts.
Beer Pong Champ (Retired)
2001 2500HD Silverado 6.0, 300hp/360torque stock.
LQ9 is higher compression. 98+ Camaro will be LS1 small valve heads, fine on a 5.3. Don't quite match the bolt on potential of a set of 243's on a 6.0.
Just a quick note, the 98+ F body heads and the 243 (LS6,LS2,799) heads all have the same size valves. The 243 ports are a definite improvement over the predecessors youre right there for sure.
Age of Acquiescence
When the cam is swapped is where you will notice the differences.
Exactly.
This is where the Gen IV LY6 6.0L blows away the Gen III 5.3L , Gen III LQ4, and Gen IV LQ9
dont forget to mention the difference between perimeter and center bolt valve covers
Exactly.
An LY6 isnt better because of the cam. It has L92 style rectangular port heads which make the difference.
1 - 20 of 62 Posts
