1 - 4 of 4 Posts
i have a speed tech two stage 4150 plate that i need to do something besides let it collect dust on the shelf. was wondering could i use one IS trash can noid and a fuel and make it into a single stage. what is the best way to do this, block off one side of each or use a T and go back/side with nos front/side with fuel like they use to do in modified street.
need tune up for about a 300 shot on SBC 406 23 degree 13.1 compression j/e nos pistons. Afr 227s heads, comp 714 in 688 exh 114 ls.
Any suggestions?
I would go with the trash can and run "T" fittings on the outlets of the solenoids and still feed all four entries in the plate.. To move about 300 through it you'll have to have around two .065 to .067 nitrous jets. Hope this helps.. SJ
helps a lot thank you. last thing what kind of spread should i put on it and how much timing to pull from 36 total. ill be calling soon to order a trashcan.
1 - 4 of 4 Posts
