1 - 3 of 3 Posts
can someone tell me how to fasten the steering joints to a piece of 3/4 molly the joint I have have the silicon boots I was thinking of putting a bolt thru them maybe 5/16 grade 8
we use an NAS bolt for those. 1/4-28 would be fine. if you are using .750 for your steering shaft and your milspec joint is .875 od you would want to use NAS part # 1104-14. if your milspec joint od is 1" you want to use NAS part # 1104-16. remember to use a jet nut.
1 - 3 of 3 Posts
