1 - 6 of 6 Posts
does anybody use these with nitrous? can they be used with aluminum heads?
I used a .027 thick Cometic which is about as thick as many steel shim head gaskets with good luck-even reused them with some copper spray.You might get into a low quench clearance issue depending how far your piston is down in the hole though.
ls1 s/s notch on 28s
My motor going together will have del pro 1094s..from what i seen some have sprayed 400 on them..ill ne only around 200 for my deal an yes they work on alum heads..they are rubber coated but ill be spraying mine with copper spray to help out on weapon also
Senior Frog
ABSOLUTELY NOT..........You can not run shims with alum heads they will not hold compression
for long.........ask me how I know :)
1 - 6 of 6 Posts
