i have a 598 shafiroff sportsman motor that kicks back and breaks the starter gears or breaks teeth off the flywheel. I run a digital 7 with a retard, i was told to run a 16volt battery to the starter which i did, i was told theres certain ways you have to fire off a motor of that cubic inch etc. If it starts cant ask for a better running engine but if it it dont and belches and kick back the starter or flywheel is history. So if you can give me any help , or suggestions i would greatly appreciate it. THANK YOU
