1 - 2 of 2 Posts
Trying to find out what would be a good spark plug to start with and gap setting for my setup.
STock block 347
9.2:1 compression
AFR185 Heads
CHP sypder EFI intake
F-cam
PTS street kit with A/A intercooler looking to run 10-15psi.
5 speed car
If any more information is needed just let me know.
plug gap depends on what ignition your using. i dont now what style plug those heads use but i use r5671a ngk plugs. i use 8 heat range. i would start with a 9 if possible and see if it fouls out the plug. you will probably end up with an 8 but 9's are less likely to cause detonation. without knowing you ignition i would say start around .025. i have a 6 series box and do .028 and didnt blow spark out at 40lbs boost.
1 - 2 of 2 Posts
