1 - 4 of 4 Posts
Ok so I recently swapped a new engine/trans in my truck and I'm In the last steps trying to fire it off finally. The starter works but the solenoid is not getting power. This is in an 02 Silverado. Any suggestions?
Sent from my SM-G973U using Tapatalk
Was this a conversion or replacing like for like-If it worked before replacement, double ck
your wiring. Maybe use a test probe and have someone turn the key to the start position
while checking. Make sure the wire didnt break somewhere during replacement.
1 - 4 of 4 Posts
