1 - 4 of 4 Posts
I built a motor and trans for my bros car 540ci,[email protected] and [email protected] and a turbo 400 manual valve body(no brake).The stall seems a little low(3500rpm) and seems a little tight.My question is should i pull the converter out and get it re-stalled and loosened up.
Oh ya the car has a 4.10 gear and crosses the line at 5700rpm and the car weighs in at 3450lbs with driver. This is a street/strip car
Thanks for any and all info
Kevin
If you get it much looser it's going to build a bunch of heat while trying to drive it around on the street, even with a good cooler. Strip only I would think it needs to be looser.
1 - 4 of 4 Posts
