1 - 6 of 6 Posts
Anyone know how the reverse idler gear is setup on a dodge ram srt10 T56?
When disassembling the trans there was only the bearing and idler gear on the shaft. However in the tremec exploded parts they speak of a thrust washer in front and back of the idler gear. In the OEM dodge ram srt10 exploded parts view they speak of a thrust washer in the back and a snap ring in the front of the gear and in the OEM dodge SRT10 workshop manual they only speak of a thrust washer behind the gear and nothing in front. Question is, which one is correct for the dodge ram srt10 T56?
Numbers 16 through 22 is the reverse gear idler setup (tremec exploded part view)
T5 & T56 building fool
Some housings didn't use a thrust washer, some used one and some used two.
I installed with only the rear washer like described in the workshop manual (tremec and dodge exploded parts view say different things) and have about 0.02" play in the gear, this sound about right?
1 - 6 of 6 Posts
