1 - 3 of 3 Posts
Kanawha Valley Outlaw Street Car Class General Rules: Street car class will be run by a sportsman ladder 4 tenths pro tree 5.00 (second) Flat is the cut off, if a car runs faster than five seconds they will have to requalify. All track safety rules apply. NO EXCEPTIONS All vehicle must be weighed after every pass before going to pits. (If you do not have your vehicle weighed after each pass in eliminations you will be disqualified no exceptions.) All rules subject to change to ensure class is competative to all vehicles.Vehicle Rules: 1. True backhalf cars and stock suspension cars only, no tube chassis cars (aftermarket bolt on suspension parts allowed) 2. Vehicle Weights: a. 2800 lbs. small block normally asperated. b. 2900 lbs. small block nitrous c. 2900 lbs. big block normally asperated d. 3000 lbs. big block nitrous e. 3100 lbs. small block single turbo and blown aplications f. 3200 lbs. big block single turbo and blown aplications g. 3300 lbs. for all twin turbo aplications 3. Exhaust must run through mufflers 4. All vehicles must be stock appearing. a. no major modifications to stock body lines. b. must have factory appearing dash. 5. Must have working headlights and tail lights. 6. Max. tire size 10.5 W slick . Any size D.O.T. approved street tire. Here are the dates: Sat. May 17,2008 Sat. June 14,2008 Sat. July 19,2008 Sat. Sept. 20,2008 Sat. Oct. 18,2008Winner $1,000.00R/U $500.00Semi $250.00 Entry Fee $60.00 Includes car, driver & 1 crew member
the rules were made this way so that the slower cars could have a chance, this is to have a good car count. these rules are for this yr only and hopefully we can have 2 classes next yr 1 being O\L 10.5 the other class will be the same as the rules above just no weight limit.
1 - 3 of 3 Posts
