I have always used 40-45* up to 100kpa, and leave about 30* in it till 5psi then slowly taper it down to
[email protected] From there yank the rug out from under it by pulling the timing back 12-16 degrees and pour the fuel to it to get it popping and banging in the pipes.
I found with the timing pulled way back and fat initially it would never get over the converter in enough time to keep trans temp under 220-230 degrees before even leaving the starting line. Now I didn't have an ice box or tank or anything like that, so some guys with that equipment might not experience what I did.
I found by adding timing and leaning it out initially that it would power through the converter easier, and once I got some manifold and exhaust pressure built, then I could let it pop and bang in the pipes to get it where I really wanted it.
