1 - 11 of 11 Posts
i have an 87 grand national trz front suspension and i was wondering what is the lightest front spindles to use without using trz areout of my budget right now
You can use a 64-72 Chevy A/F/X body spindle. You just have to ream the ball joint out.
Would you need TRZ's billet steering arm since those are rear steer spindles? Or can you just swap sides with the stock arms?
I would like to lose some weight on the front of the car before ordeing front brake I would like to konw wich spindles to go with
The g-body spindle weighs 11# and the Nova spindle is under 6# with the TRZ arms. I'd say it's an easy 10# of unsprung.
What does the trz arm weigh? I've looked at their arm but I run coilovers on all four corners and like the ride height and car behaves as should, I don't want to lower it anymore than I already have, does anyone make a lightweight spindle that is stock height?
1 - 11 of 11 Posts
