1 - 3 of 3 Posts
· Registered
i am actually going through this on another car right know.anglia and 67-9 camaro are the two different spindle mount styles offered.i would use the camaro size it is a bit more beefy.as for installing,there are alot of different ways to do this.i am going to take an aftermarket mustang II spindle and machine it to fit.it has enough material where i need it.you could do the same with yours if you have the material.you could also try to find bearings and seal with the right i.d. and o.d. you may get lucky.you will have to do something with the caliper mount also.it is worth the effort if you are gonna try it not only does it save a little weight but they look bad ass on a real car.if you have any more questions give me a call at the shop in the afternoon.734 466 9378
1 - 3 of 3 Posts
